I am working on a control panel for a heater that utilizes a specialized solid state relay based on the following Carlo Gavazzi RM1E analog phase SSR (https://www.gavazzionline.com/pdf/RM1EAAdatasheet.pdf) except that rather than 0-10vdc, it uses I believe 0-120vac. The SSR is made by Carlo Gavazzi for Infratech to be used with “any” wall dimmer.
My question is, will the White series dimmers be able to work with an analog phase SSR like a standard wall dimmer in this circumstance?
If it helps, my objective is to control infrared heaters using the SSR, but would rather have the smart dimming capability instead of a “dumb” dimmer.
Thanks for the help?
