Dimming no longer works after installing Aux to 3 way. (Blue Series)
First, these switches are incredible and the community here is awesome. So thank you for being awesome.
I have 2 Blue 2-1 switches and a few more on the way. Almost every switch in my house is a 3 way, and none have neutrals. They are wired up in the way pictured below.
3-way-power-at-light2
While I waited on my Add-on switches I just bypassed one of the 3 way switches by caping the traveler and connecting the line and load together. The new switch functioned perfectly, and worked as a dimmer. Today the new Add-on switches came in, so I wired them up and was able to get the working with the exception of dimming. The blue LED on the Blue Series dimmed like it was supposed to, but the lights didn’t dim at all. Here is the wiring. Any thoughts as to why everything except dimming works?
I would check the switch settings first.
Parameter 22 - Switch Type - should be 2 = Multi-Way (3-Way) with an Aux / Add-On Switch
Parameter 258 - Switch Mode - should be 0 = Dimmer
And this is why the community is awesome. Thank you @Bry. I’m going to go hide my face in shame now. lol
