Direct Association turns bulbs off, but not on
Good afternoon
I’ve successfully installed a Red series switch that I intend to control three Illumin RGBW bulbs through direct association. I set it up successfully through the association tool, and it will turn the bulbs off, but not on. I can turn on the bulbs through the SmartThings V3 hub I’m using.
The switch is installed with a neutral wire, and does not directly control a load.
Any ideas what I could try?
Can you post up which tool you used to set up the associations and also logs when you press the switch toggles?
Think the OP still needs help??? :rofl: :rofl: :rofl:
