Fan 3 way - Blue switch and Aux
When you say Blue switch I’m presuming that you are referring to the about-to-be-released Blue 2-in-1 switch. That one is NOT rated for motor loads, so you can’t use it with a fan either in a 2-way or with an Aux switch. However, Inovelli is developing a Blue FAN switch which will suit your needs. It will work with an Aux and vary the fan speeds.
