I’d like to be able to turn off the blue “status” light inside of my fan canopy because it makes my fan light up like a UFO at night. I didn’t realize it stayed on the whole time, or I would have thrown some electrical tape over it before putting the canopy back on.
I don’t have one, but it looks like you can adjust the LED intensity via P97 and the color via P99. I’m guessing that 0 on P97 will turn it off.
Thanks! It’s daytime, so I can’t be sure, but I set it to 100 and was able to tell that it got brighter. So then I set it to 0 and will verify tonight that it is indeed off. I didn’t see it as a config value in HA, but didn’t think to look at all of the other attributes that don’t show.
EDIT: Just to add in case someone searches for this. Using ZHA, this is what I set to 0:
I can confirm that’s the correct parameter. (I use Zigbee2mqtt not ZHA, but it’s the same parameter number).
