Firmware v1.48 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
https://files.inovelli.com/firmware/
Not sure what the “file link above” is, but if you’re looking for firmware, that’s where to go.
The direct link to v1.48 FW
https://files.inovelli.com/firmware/LZW31-SN/Beta/LZW31-SN_1.48.otz
Traversing the directory tree, it looks like the updated URL is https://files.inovelli.com/firmware/LZW31-SN/1.48/LZW31-SN_1.48.otz
Thanks, I have fixed the link.
Quick question: when pressing and holding it still seems there’s a delay. If the press delay is set to zero is there any way to remove any delay when holding / dimming? Thanks as always @EricM_Inovelli!
Hmmm, I believe there still needs to be a delay to determine if the user is just pressing the button vs. holding it. You can adjust the dimming speed to 1 or 2 to make the delay less noticeable.
Is that current delay configurable? I feel like I have everything set to the lowest delay.
As always appreciate your work on this!
There is a request to apply the same “scene enabled” delay to convert from push to held. It is not currently configurable from the 700ms like the scene delay is.
There is also a request to change the dim/ramp rates from seconds to ms. Then the switch could ramp/dim way faster (sub-second) vs. the current 1s fastest possible speed.
There is ALSO a request for dimming up vs. down at different rates, but I haven’t seen that grab much traction.
It definitely feels like you don’t need to specifically configure it if you’re already choosing to disable the functionality. I’d just have it default to as short as possible. ¯_(ツ)_/¯
