@mamber It is a firmware limitation that was introduced to reduce the complications if a user were to set the minimum level higher than the maximum. For example, if you set the minimum to 99 and the maximum to 75. At the time we did not see a need to have a minimum that high, but do see it now. We can program around that scenario though. That’s why we have beta releases is to figure this stuff out.
