Thank you I have ordered the GE switch which should arrive Saturday. I’ll then add both devices per the directions you provided.
I am not sure what the switch parameters were that you sent me. Is that what I need when I add the Inovelli switch?
Thank you,
Brian
harjms
July 16, 2020, 9:44pm
22
@the5evansfamily the parameters are to program the switch to be a non-neutral device with aux switch. It changes its characteristics based on the parameters. Either do it from the switch or Hub.
harjms
July 17, 2020, 12:16am
24
Bry:
Install the switch
Connect the switch to your hub
Set the parameters
Way easier this way. Had no issues with switch accepting parameters.
So it’s all good to go! Thank you I had to make one change on the parameters and then the add on switch worked.
Many thanks
Brian
