I have a 3 way circuit where I’ve got a neutral in the box with the inovelli switch, but not the box with the aux switch. Currently I’ve just wired it up as a non-neutral setup. I know I could rewire to get the neutral to that box, but I don’t think I’ll bother since the current non-neutral setup works fine. My question is: Is there any reason I can’t use the neutral at the box with the inovelli switch, and just use the hot wire I have in the aux switch box to power the aux switch instead of a neutral? That way I don’t need the bypass.
Also, on the subject of the dimmer bypass. Can anyone explain to me exactly how they work? I know the inovelli dimmer requires a 25w load to function correctly. If I’m using a dimmer bypass is that inovelli switch drawing a constant 25w of power?
Thanks for any insight
