Awesome, I can see what we can add to make them show up prior to an action.
I opened a PR to add the actions to the expose list here.
Great, thanks for the code.
running into this same problem now. Just installed my blues. Smart bulb mode. 500ms delay. Tried the button press sequence probably 20 times without any success.
I just finished installing four Inovelli Blue switches. Three of them work no problem, and I can use switch events for automations in HA flawlessly. But one of the switches won’t register any events in HA. Zigbee bindings work on all the switches, but just that one switch is being troublesome with events.
I’ve tried resetting the switch by holding up+config for 20+ seconds until it blinks red, but no luck.
Anyone else know how to fix this?
Ok, so in HA, I decided to toggle each switch and update the button delay settings.
I went one by one, testing for events each time. When I toggled the “Local Protection” switch from Off to On to Off again, I started seeing events get published. It might have been the case that HA’s logical representation of the Local Protection state was different from the actual switch Local Protection state, and forcing a change syncronized the values between the devices.
Either way, all is working now!
