@dgrekov fix pushed to github
Sweet!!! They merged my fixes ⦠You can go back to using the inovelli official drivers
Pushed a fix for a reporting issue when switching from color to ct modes⦠Issued another pull requestā¦
@bcopeland We have merged that pull request as well.
Thanks for the work on these!
Anytime @EricM_Inovelli⦠I had fun doing it
I pushed an update to my GitHub on a couple of minor bug fixes⦠I also updated the command class versions to match the actual devices command class versionsā¦
Unexpected side benefit ⦠it seems to reduce chatterā¦
If no bugs reported I will create a pull request to merge into official
Hey @bcopelandā¦
Any chance we could get the special effects like the Aeotec written in the drivers?
- lightEffects : {1=Christmas, 2=Fire, 3=Flash, 4=Police, 5=Random Colors Fast, 6=Random Colors Slow}
-Travis
There would have to be hardware support for the effects⦠Driver level effects would be too network intensive
Just pushed a major update to the bulb drivers LZW-41/LZW-42:
- major re-write for new coding standards / cleanup
- stabilization of color temp and color reporting
- re-organization of device data for standardization / addition of serialnumber, hardware ver, protocol ver, firmware
- re-work of associations
- fix of long-standing bug in lowest CT range
This update should also help alleviate delay issues when sending commands to many bulbs at onceā¦
I recommend hitting configure on your devices after updating⦠But this is not requiredā¦
You can get them now from:
and:
I have issued a pull request to Inovelliās official github:
Original thread on Hubitat community:
Tagging @EricM_Inovelli
Awesome, thanks for doing that. Question, I see in your setColor and setColorTemperature methods that you are querying the bulb after changing its color. I believe the bulb automatically sends its color status after changing the color to the lifeline association group (group 1). So I think you are creating extra traffic with that and it can be left out. Otherwise, great job!
Edit: I may have been querying the colors in my original driver so that may be where you can that bit from. I think I changed it in the device handlers I sent to SmartThings for WWST certification.
Annoyingly this doesnāt always work⦠The problems I have had with removing this totally is that if one of the values does not change it will not report ā¦
Also since it is using switchColor CC V2 instead of V3 we donāt get targetValue ⦠so if you are using a transition time it will get stuck in a middle valueā¦
So what I did was schedule the query for after transition duration⦠Makes it so much more stable and predictableā¦
Nice, Ok. That makes sense.
and I really like the transition time⦠itās not a jolt to the new color or colorTemp⦠itās a nice smooth transition⦠but it made reporting almost useless.
I like the new driver. The color transition works great. I did add a pull request to add back in the dimming speed for on and off commands.
@EricM_Inovelli Does the firmware support configuring a fade for on, off, and level changes?
| Parameter Number | Parameter Size | Parameter Name | Values | Values Desc |
| 2 | 1 | Memory Function | 0 (Default) | Remembers Last State |
| 1 | Bulb turns ON after power outage | |||
| 2 | Bulb turns OFF after power outage | |||
| 51 | 2 | Color Adjustment (Warm White) | 1387 to 4999(Default) | Changes the Kelvin from 2700k (1387) to 4999k(4999) |
| 52 | 2 | Color Adjustment (Cool White) | 5000 to 6500(Default) | Changes the Kelvin from 5000k (5000) to 6500k (6500) |
Thanks! Thatās an awesome resource. I had no idea that existed.
Anytime⦠I always hit up the z-wave alliance page when writing z-wave driversā¦
@bcopeland - So Iām still having an issue when I group the bulbs in hubitat with slow responsiveness after sending multiple commands. Sorry for the size. Hereās my best example:
Hubitat Group dimmer issue or bulb responsiveness? @EricM_Inovelli
Wow ⦠Yea thatās not normal⦠Where is your hub in relation to this bulb?
Give you an example at my home I currently have:
20 LZW-41 Multi-White Bulbs
7 LZW-42 Multi-Color Bulb
And at sunrise and sunset I have rules that hit every bulb including from other brands⦠And sets color temperature⦠This is a ton of bulbs reacting at the same timeā¦
