I think Inovelli should make a "Stealth" Thread switch that physically flips
​I’ve been thinking about the “social friction” of smart switches and I think there is a huge opening for a “Sleeper” switch. We have the high-end stuff with LED bars and sensors, but I think a simplified, analog-style Matter-over-Thread rocker would be the ultimate solution for “tech-haters” or anyone who wants a clean, traditional look.
​​How it Works (The “Player Piano” Effect):
The idea is to have a smart switch that looks and acts 100% like a traditional manual rocker, but it physically moves itself to stay in sync with the network.
  • The Mechanism: Instead of a momentary paddle that stays in the middle, the rocker would have a simple metal plate inside. An internal electromagnet would pulse to physically “throw” the rocker UP or DOWN when triggered remotely.
The “Sleeper” Build – What do we keep?
To keep the look completely “analog,” I think skipping the LED bar is a must. The physical position of the rocker tells you the status, so the light pipe just adds unnecessary “tech” vibes.
​However, I’m curious what everyone thinks about the other sensors:
  • Cost vs. Features: I think skipping the mmWave and humidity sensors could bring the price down significantly, making this a great high-volume “contractor” switch.
  • The Debate: Or, is it better to keep those sensors hidden behind the plastic so it looks like a dumb switch but acts like a pro-grade sensor? Personally, I think a “no-frills” version focused on the mechanical snap and Matter Binding is the missing link for people who just want their smart bulbs to work with a real switch.
​From the outside, it would be indistinguishable from a standard decorator switch. I think there’s a big market for people who want a smart home that doesn’t “look” like a smart home.
​What do you guys think? Would you prefer a stripped-down, cheaper version of this, or would you want the sensors hidden inside?
Honestly, I don’t think that’s Inovelli’s market. They’ve basically based their whole brand around the light bar and packing more features into their switches than anyone else has.
If all you’re looking for is a basic switch that doesn’t look like a smart switch, using an actual dumb switch and a Zooz or Shelly relay behind it seems like a relatively simple option that’s possible today.
I personally don’t think there’s a sufficiently large market to justify building a switch that mechanically moves up / down.
You’d lose dimming control at the switch though and that seems like a pretty big missing feature when you’ve invested in smart bulbs already.
If I am understanding you correctly, what you are describing can be accomplished by use of an Shelly 1 Gen4 module.
I like the idea of a “physical” switch, but I am guessing it would be difficult to either use a solenoid or a motor to actuate a physical switch up or down. It would kind of be like an older audio amp/receiver (maybe some still have?) that has a motor to turn the volume knob/potentiometer up and down.
Nice idea, but I don’t know what it would take to do it.
