Inovelli Blue 2-1 Dimmer LED on Full all the time?
The 2nd dimmer I installed the LED is full White even when dimming it. The lights dim up and down just fine but the led indicator always shows full brightness. I had the same issue when I first setup the other switch but somehow accidentally fixed it. I now have both switches setup the same, but this one is still doing it. What am I missing?
Ok now both dimmers are behaving this way. Inovelli any ideas??
Did you factory reset a switch to see if the LED bar is normal with the default settings?
If not, I would do that to see if the LED bar acts normally before you change any settings. If that is the case then pay attention to see what happens when you tweak a setting.
Parameter 17 set to 0 would do that, assuming you have the on LED bar color P95 set to white.
Does it change color or brightness for on and off?
The other is a notification, 2 clicks on the config button should clear it if P262 is set to 1.
Thank you! You’re a genius! I do set them to white. I don’t even know what load level is so my first thought was to disable it. I set it back to default and they are working as expected. Thank you so much!
