Inovelli Blue Switch- Flashing Lights On/Off
Hi I’ve had a Blue switch operational in a room since 9/2023. Yesterday I noticed that the lights were flashing on then turning off repeatedly. This probably happened around 8pm. When I saw it was flickering i tried pulling the hard power. After turning it back on it started flashing again. I left it off overnight and replaced it with another new switch I had and it seems to be working okay again. No connections seemed loose.
Oddly enough when it turns on the LED bar on the right doesn’t turn on or change to any colors. It makes me think its stuck in a sort of reset/boot loop situation.
Did the switch break? Any thoughts as to what happened? Note I did update the firmware in the last few weeks through home assistant but nothing otherwise has happened recently. Also, I have other switches in the house which seem fine.
The load is 4 can lights with LED bulbs (dimmable).
Video of the issue at https://youtube.com/shorts/q5gVOvOYp9U
Maybe, but I would try a factory reset to see what happens.
Agree with what @Bry mentioned. Sometimes after a firmware update, the switch needs to be reset.
If that doesn’t fix it, can you let me know what firmware version you had installed before and which one you went to? It may be possible that you were on Leading Edge and it got switched to Trailing Edge and there’s some weirdness going on.
