Inovelli Red Switch set to No Neutral
Using a hub other than Smartthings, how do I set the switch to No Neutral ?
p.s. I am using a ISY hub
Only the dimmer can be used non neutral. Lzw31/lzw31-sn
That, I know… My question is that I believe that for a single pole use, the switch is set to need Neutral. There is a description on how to set the dimmer switch to No Neutral when using Smartthings, but I am using ISY.
So you have a dimmer, not a switch?
No sure about ISY but you can do it from the dimmer. Press config button 12x to toggle neutral/non neutral
That’s after getting into configuration mode. Press and hold config button until LED bar goes yellow, then press configure button 12x.
See Knowledge Base Redirect – Inovelli
Follow the non neutral portion of instructions. Aux switch part is not important.
T H A N K S !!!
That is veey helpful
Thanks also for the valuable information
