I can’t understand why it’s so hard to find information about compatible bulbs. The Compatible Bulb & Fan App - Inovelli app used to work, but it now just goes to a “Thank you for confirming” page (not sure what that is even referring to). That link is what Inovelli points us to from Bulb & Fan Compatibility App | Inovelli Help Center . I want to love this company but something so simple as a database of bulbs known to work with their high-end switches should be trivial to maintain, so it makes me wonder if the company is OK. Thoughts?
They are a small company and may not even know that page stopped working, or have time to fix it. Looks like it was an MS integration of some sort so it probably breaks all the time… On top of that, most companies gave up on compatibility lists since bulb makers will do multiple production runs of bulbs, each with different drivers and no way for the end user to tell. This means you could buy two of the exact same, as far as you can tell, bulb but have one not work when the other does.
We are doing great - better than ever actually! Thanks for asking!
