Hey all – the knowledge-base is deployed and ready for first round feedback!
NOTE: I’m still working on adding more wiki articles and tagging them properly so that we can play more with the filtering. I should be done with it either tonight (Nov 10th) or tomorrow (Nov 11th).
Location: https://community.inovelli.com/knowledge-base
Overview
I’ll give a quick overview as I think it will help as we think through the user experience.
The purpose of the KB is to have a centralized location that is continuously updated (by us and the community) of how-to’s, setup instructions, troubleshooting and anything else we can think of.
When in the KB, you should be able to select various filters to get to your problem. I think there is a search function coming, but for now it’s just a series of drop-downs and selections based on tags.
In addition, these will be linked in our instruction manuals so each URL is unique based on your selection.
Ex: The specific URL for the Red Series Dimmer for SmartThings users would be something like: community.inovelli.com/knowledge-base?tags=smartthings%red-dimmer (note this is not a live link, just an example). So the sky is the limit as to what we can now put in manuals and not only that, we can keep them updated in real-time (as we’ve discovered print manuals are often outdated).
Feedback
With that in mind, let’s create a first draft of bugs and/or enhancements. Some may be in scope, others may not be. Either way, we can add it to the list and hopefully get it taken care of. This is top priority for me personally as I believe it will help with customer service and user experience.
Running List - Bugs
Duplicate values
Fonts are messed up when KB is deployed
Some tags can’t be selected for some reason? Possibly bc tags that aren’t used can’t be selected (investigating)
Mobile is not optimized
Checkboxes aren’t checked when selected
Running List - Enhancements
- Make tag column wider so words aren’t cut-off
Open Questions / Comments
If someone doesn’t know the hub version they have – ex: They have SmartThings and don’t select v3 – should we force them to choose a version?
Right now, we’re forcing them to select SmartThings and a version. I think there should be a checkbox next to SmartThings that someone can select and then if they want to drill down further, they can click the drop-down and select the version.
