Lzw31-sn and HS-WA100+, with neutral wire, 3way setup
Hi,
I have a LZW31-SN setup in a 3-way with neutral wiring configuration (line in same box) paired with an HS-WA100+ companion.
I’am able to control the light from the inovelli switch, but the companion switch does not work…
I use home assistant, and configured the dimmer with following parameters :
  • Association behavior (13-112-0-12-2): 3-way (1)
  • AC Power type (13-112-0-21) : Neutral (1)
  • Switch type (13-112-0-22) : Auxiliary switch (2)
Do I miss something ?
Note, when I change the wiring to use a dumb switch, and use the following paramaters, everything works well :
  • Switch type (13-112-0-22) : Dumb switch (1)
Thanks.
