LZW31-SN and LZW42 Associations
Which groups should I use for these two? Group 2 and 4 or 3 and 4? Dimmer has 1.61 gw and bulbs have 2.31 fw. It’s been a while since I’ve played with this combo and dimming from the switch doesn’t work very well. On/off is fine.
I used 2, 3, and 4 when I had it setup. It worked for dimming and such but I never did get the bar to sync with dim level of bulbs.
I have mine setup with group 2 & 4 only and it works well and LED bar syncs to bulb level. I originally had group 3 also but there was a lot of lag when dimming from the switch. I’m not sure what I missing out on without group 3 but I’m happy with my setup.
