LZW31-SN association for virtual 3-way dimming (zwavejs2mqtt 5.10.1)?
I was hoping someone could point me in the correct direction for doing virtual 3-way dimming association with LZW31-SN and zwavejs2mqtt 5.10.1. I see a lot of discussion of setting Parameter 12 to 11, but the newest zwavejs2mqtt seems to have broken Parameter 12 into 4 different toggles. See the below screenshots.
Also, which groups should I create associations for? I have one dimmer wired to the lights, and a second just wired to power with no load. Do I just need Group 3, or do I also need Group 4? Do I need to create the association on a particular switch (the load switch vs the virtual/aux switch)?
This is how it looks in Home Assistant 2021.10.6:
And this is how it looks in zwavejs2mqtt:
All help appreciated,
Omen
Load switch gets a value of 15 (all selected). No load gets a value of 11 (all but z-wave hub)
Edit: Groups 2,3, and 4 in both directions.
Change the zwave hub one.
Ah, refreshing the values, converting 11 to binary (0b1011), and it makes sense. Bit 3 (112-0-12-4) needs to be unset, and that is Association Behavior: Z-Wave Hub. Mystery solved, thank you!
Last question for now. When you say in both directions, does that mean create the group association on both switches in zwavejs2mqtt?
Now I just need to get all my dimmers upgraded to the newest firmware, but that is a tale of woe for another time.
Nov 03 18:41:25 ovejas-pi zwavejs2mqtt[28804]: 2021-11-03 18:41:25.871 INFO ZWAVE: Node 37: value updated: 112-0-12-1 1 => 1
Nov 03 18:41:25 ovejas-pi zwavejs2mqtt[28804]: 2021-11-03 18:41:25.874 INFO ZWAVE: Node 37: value updated: 112-0-12-2 1 => 1
Nov 03 18:41:25 ovejas-pi zwavejs2mqtt[28804]: 2021-11-03 18:41:25.877 INFO ZWAVE: Node 37: value updated: 112-0-12-4 1 => 1
Nov 03 18:41:25 ovejas-pi zwavejs2mqtt[28804]: 2021-11-03 18:41:25.880 INFO ZWAVE: Node 37: value updated: 112-0-12-8 1 => 1
Load to non load associations. Set groups 2/3/4.
Non load to load associations. Set groups 2/3/4.
Total of 6 in all.
Got it, thank you!
