I have two LZW31 SN switches both with neutral wires and both used in different 3-way circuits with the power and load in separate boxes. Both LZW31 SN switches are on separate circuits, but I believe they electrically interfere with the other circuit somehow. Problems only exist when both circuits are powered on.
I have an upstairs light switch Box A which is upstairs light (smart switch), upstairs fan (smart switch) and stairway light (LZW31 SN, power side).
I have a laundry room switch Box B which is stairway light (dumb switch in a 3-way, load side) and laundry room light (LZW31 SN, power side).
I have a laundry room switch Box C which is laundry room light (dumb switch in a 3-way, load side).
Issue 1) with the stairway light when the dumb switch is in a certain position say down, and the LZW31 SN stairway switch turns off the LED lightbulbs will glow slightly.
Issue 2) with the laundry room light if the dumb switch in a certain position the light will turn on for a few seconds and eventually turn off. If the dumb switch is in the other position the light acts normally.
When ringing out the wires in the original 3-way it was odd that there was voltage on the part of the circuit that should not have been used. The neutral wires in Box B are separated between the two different electrical circuits. Additionally, I killed the smart stairway light which was an on/off red series at the time (thank you for the customer support replacing the switch when it was definitely my fault). During that time, I pulled the air gap on the switch and the laundry room 3-way circuit had 0 issues until the other 3-way circuit was brought back online.
I really need some help sorting out the issues between these two circuits.
