I have recently installed several various Inovelli switched to replace dead and dying GE Z-Wave switches in my home. After about a month I have noticed some weird behavior with the Red Dimmers only; they will flicker seemingly at random probably about once an hour. Its a quick flash the last proably less than a second but I notice it every time it happens. This does not happen to any of the Red or Black series non-dimmer switches I have installed. The two Dimmers that this happens to are configured completely differently too; one is a single pole with out a neutral, the other is a 3-way with a GE Aux switch and neutrals at both switched. I’m wondering if this may be a known issue with these switches or maybe a config setting that I might have missed? Any thoughts?
Switch 1 Setup
Switch 2 Setup
