Running on Hubitat, and everything has been peachy .. I just upgraded the switches from 1.47 to 1.52, and everything seemed fine, so I finished upgrading the rest. Then I realized that all of the scene control has stopped working, and as soon as you touch a paddle, the lights just come on.
I tried the settings in the drivers to adjust the button press delay, and enable/disable the physical on/off delay among other things … but they either aren’t getting applied in the switch, or just don’t work.
Am I missing something? It’s like my Red’s have turned into Black’s …
Its a known “bug” with that firmware. It automatically sets the delay between button presses to 100ms instead of the default 700ms. Configure delay back to something longer and your scene control should work again.
I had tried setting it explicitly to disabled (vs. “no selection”) and then back to no selection several times; I don’t recall if I had set it to enabled in any of my tinkering. I did just try setting it to enabled, waiting a minute until I was sure that param51 reflected the change, and then switching it back; that appears to have solved it.
Well … being honest here, as soon as I got it working; I tried to flag it as the solution - but for the life of me, I can’t find an obvious way to do that
I can confirm this is an issue when upgrading to 1.55. After the upgrade, some dimmers would not register anything other than single taps until I toggled Parameter 50 and 51. Seems like 50 has to be at least 300ms to receive double tap, in my experience. I also have to disable SBM on non-smart bulb dimmers.
I’ve noticed that too. I have not been able to get the Inovelli to register a double-tap below 300ms even though I can consistently double-click under 200 (gamers click at 125 or less)…
