LZW31-SN status reversed when with local activation - v1.47 & v1.48
I am using an Indigo hub. My LZW31-SN’s were working fine except I wanted to fix the status LED issue. I am using v1.35. I upgraded to v1.47 (Z-Wave & Holtek), then to v1.48 (Z-Wave). The dimmer works fine remotely, but when I activate the dimmer locally, it inverts the status in my hub, off is on, and on is off. The switch itself is not inverted, up is on, and down is off. I flashed it twice as recommend in the instructions. Any ideas?
Nothing that a factory reset wouldn’t fix… All good now.
