I had a 2-gang box for a ceiling light & fan. I installed the new Light/Fan combo and decided to add a Red-series dimmer (LZW31-SN) as a parent switch for a light across the room. I installed Line, Neutral, & Ground, but didn’t install a load. I set up the Association Tool (using SmartThings) to have this switch turn on two other lights, but can’t get it to work. I also noticed that when I saved my settings (ramp rate = 0 at the switch and z-wave command), the switch still ramps slowly. When I go back into settings, the ramp rate section says “tap to set” (https://imgur.com/YcgQxZF) as if I never set it, but when I open the settings, it shows “0” (https://imgur.com/mEusYnK)
Am I having this issue because I don’t have a load running from the switch?
