Did you see if you could still fit the canopy module? There looks like a lot of room in the manual for that fan, so may just need to zip tie it to the mounting bracket to keep it secured.
I need to find a fan that has a drop down like the fan mounting kit like you showed in the second link or use the zip tie idea above. I only buy (bought) flush mounts previously when I didn’t have vaulted ceilings or higher than 8’ ceilings. Otherwise, they were always at least a 6" drop.
I would buy a fan that does not have integrated LED lights that you can’t replace. Anything with a A19 socket (or similar) should be good to go. Otherwise you may find yourself having to install an Aeotec Bypass to keep the light from staying dim 24/7.
The bigger one comes pre-wired for its included remote receiver, but the wires are standard colors and you can cut the connectors off to connect with the LZW36 canopy module. They both use regular light bulb sockets, and I am happy with them so far.
These fans are convertible from downrod to flush mount by taking a few screws out, and the procedure is clearly described in the manual as well as on the Home Depot web site in the 44" fan installation video.
I’m happy with them so far, and plan to pick up two more to replace old fans in our remaining rooms when I get around to installing our remaining LZW36’s…
It does not have a canopy module like most others… the module it built into the motor unit…
Being that the switches use RF to communicate with the Inovelli canopy module… is there a way to pair the RF switch with the built in receiver of the fan… I know the answer… but I can hope… it’s a nice fan that matches the decor of the room. It does have an odd start up… where the motor rotates back and forth to sync before starting normal operation…
@ljvb That IS a nice looking fan. Unfortunately, this fan has a DC motor, which would be incompatible with the LZW36.
I wish the companies making these DC motor based fans would either create a Z-wave/Zigbee interface or leave hooks for 3rd party vendors to create them…
