I’m having an odd issue with my new switch. When I turn off the light, either from the physical switch or via z-wave, it will turn itself back on again after 10-30 seconds. I don’t believe the issue is on the z-wave side because when I turn it off from the physical switch my hub shows that it’s off. Then it turns on and the hub doesn’t update until a few seconds later. This makes me think that it’s not getting commanded remotely but rather the behavior is originating from within the switch itself.
Has anyone else seen this?
