I recently got a set of LZW42 bulbs for the office to have some circadian rhythm temperatures applied to the room. I have the bulbs set up in association with the Red Dimmer switch, which is currently set to on/off mode. Color temperature seems to have been working perfectly… except for one bulb which is very blue. I’ve confirmed that the bulb is using color temp only, and is on the cooler side {“warmWhite”:39,“coldWhite”:216,“red”:0,“green”:0,“blue”:0} . Both the two bulbs in the picture are set to the same setting.
Any ideas if this is a hardware issue and I just need a new bulb or if there’s some possible weird setting that is causing it to be so blue?
