LZW42 suddenly doesn't want to change white, Hubitat
I have two LZW42 bulbs set up in my Hubitat. These bulbs worked great for over a year but all of a sudden I am now having issues with them changing to white via scenes. I can go to the device page and change them to white and also can do so through Alexa. But, I can no longer change them to white through scenes, or even a dashboard. I’m having no issues controlling them via scenes for colors. Colors work fine. The problem is only with white temperatures. I’m not sure why this is all of a sudden an issue.
Is there a new firmware that I need?
Thanks
Honestly this sounds like a Hubitat issue and not an inovelli one. I would post over there and see if anyone else is having similar issues.
I’m not sure these days who our Hubitat folks are outside of @Hubitat being a member here.
Thanks for the tag. It appears that @BranDot has cross posted in our community. For others who are watching this issue, please check out this thread:
I changed the drivers to the stock Inovelli ones included with Hubitat. When I set these bulbs up initially, I had to use a user made driver because the stock ones were causing issues with my hub for some reason.
So far, so good though with these new Inovelli drivers.
Mark as resolved if it seems fixed @BranDot!
I seemed to have resolved this issue by changing my drivers to the newer Hubitat Inovelli drivers.
