Hey guys! I recently made the switch from smart things to home assistant and trying to figure it all out. I’m having some issue with both sets of LZW45’s that I have at the moment. One set, when triggering a scene to change color and brightness, it will take 3-5 times of triggering that scene before the brightness adjust right. For example, I have a light blue color with a 25% brightness in a scene. When first triggering that scene, it would take it to around a 10% brightness purple. If I trigger it a few times, it will eventually correct itself. My other set will dim down after I set them to 100. They will come on at the brightness and slowly dim down at increments until it gets to around 80% brightness.
Lastly, they both will not set the the color that I click on the color wheel. I can click green and it will be blue, and some colors will not change at all when I select them.
I assume I have something integrated wrong through Z-Wave JS. I just did a normal Z-Wave integration. As I mentioned, I’m very new to HA so it’s likely I’m missing a simple add on or something. Thanks in advance for your help!
How many zwave devices do you have? Did you try reverting the open zwave config changes?
