I’m using a White series smart on off switch in a virtual 3-way configuration with a Matter binding to another identical switch where the load is connected. The first switch has no load connected to it so I wanted to disable the relay by turning off local control but the binding only works with local control enabled. Which means the relay is clicking away for no reason. What I’d like is for the command to still be sent to the bound device if local control is disabled. Or a setting to enable this mode
Have you tried putting the On/Off switch into smart bulb mode?
I considered that but smart bulb mode would leave the relay energized which maybe isn’t a bad thing. I guess it depends on the relay type. If having it energized requires a constant power draw that leaving it off wouldn’t, then leaving it off would be preferable
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
