Currently I have a LZW31-SN in my hallway with a regular 2 pole switch acting as an Aux switch. I want to replace that 2 pole with an Inovelli switch so i can hopefully control dimming on both sides(?) and the notification LED’s on both ends. I recently acquired 2 VZW31-SN.
my question is, the current LZW31-SN capable of working in a 3-way with one of the other switches models, should I move it and start the config process over with 2 matching VZW31-SN? if I mix the two will i loose any functions…
I have 2 sets of these, so i can match up the VZW31-SN and LZW31-SN.
do the older LZW31-SN’s work in a 3Way together like the newer ones?
I currently do have a naturals
