Need help in 3 way setup for blue 2 in 1
I can use some help with a 3 way setup.
The first switch is where the hot wire is coming from. However there is no neutral wire here.
The second switch is in a gangbox with anotehr switch and does have a neutral wire
20230215_080040
This three way controls one Hue downlight light which I plan on having in smart bulb mode. Can anyone assist in the best way to wire this up? I prefer to use smart switches in both but if not possible I do have aux switch I can use.
Pass the neutral and hot to the first box. Then use bindings to sync the switches. Which hub are you using?
Awesome this worked!
Took me a bit to figure out how to pass the neutral wire from the second box to the first but I figured it out and its working perfectly. Thank you!
