Non-typical Non-Neutral 3-Way Guidance
My settings at the switch were not set correctly even though I set them at the hub initially, my aux switch now works as normal. See this post to see how I fixed it.
It was a little different for this switch since it was non-neutral and momentary for the settings, but regardless setting the parameters at the hub was not enough to get full function.
