Now when I flip the dumb switch into the “bad” position I can’t use the smart switch to turn on the lights at all. The led on the smart switch will get brighter like normal but it doesn’t turn on the lights. When I flip the dumb switch back to the good position the smart switch works fine. I haven’t changed any wiring so I’m not sure why it’s doing that now. I did hook it up to homesense to test it out but that was the only change.
@Eric_Inovelli, I recently was able to get the dimmer switches working ok with the 3 way by changing the neutral setting like @Newlance mentioned. I don’t see this setting on the on/off switches. Is this something that wouldn’t apply or could this be a potential fix if the option were available?
Great question – no, we didn’t put this in the On/Off switches as when we tested everything, they were able to get the auto-detection figured out (ie: whether or not your switch is using a dumb or aux switch) and every scenario we tested (listed in the wiring manual) worked perfectly.
It wasn’t until we saw the issues pop up in the forum that we figured there may be an issue with some of the 3-Way setups. Even then, I’ve personally replicated a lot of these setups to no avail in getting the same issue, so it’s hard for us to pass this info onto the manufacturer.
Once we do figure it out though, I’m hoping it can be a firmware fix as when we initially built the Dimmers, they had auto-detection built in, but there was a lot of problems with it, so that’s why we chose to have the end-user manually configure the dimmer (I’m hoping they can figure out the auto-detection as manually programming comes with its own set of problems).
Net: We’re trying to replicate the 3-Way issues here at the office, but haven’t been able to experience the same results. Now that things have died down a bit (Black Friday, bulbs, etc) we’ll have more time to dig into the issues and see if, hopefully, we can diagnose what’s going on.
I can say that the manufacturer is eagerly waiting for a diagnosis and they are definitely willing to help. Maybe what I can also do is start a PM with them and anyone experiencing this issue so we can quickly get this resolved. The only issue is the language barrier and 12hr difference. But, if you’re open to it, I’m happy to set something up!
@Eric_Inovelli for what it’s worth, i also work in the electronics industry, though a different field (automotive.). I work exclusively with our international department and have daily dealings with our dealers in China. I also travel there 2x per year (preparing to go December 1st this year.) I have to assume based on the time difference you reference, this is the area you are referring to. I am not fluent in Mandarin but know enough and have a lot of contacts there.
Yes, correct, the manufacturer is located in China (no US ones available for Z-Wave
Happy to coordinate something for sure as I know you were having issues with the 3-Way setup!
I just tested out the on/off in my jig and with an incandescent bulb I experience no issues. Both sides work as expected. With a single bulb (normally more than 1 is in the load but my jig only has 1 spot) that’s rated as 125mA, I see switching problems when the dumb switch is on the traveler leg. If the dumb switch is on the load leg then the smart switch will switch the LED on and off no problem and I can switch the dumb switch on and off no problem.
I’m assuming the manufacturer is in China. I do know someone who speaks fluent mandarin and is well versed in electrical wiring and circuits so they could has things out potentially.
I’ve attached another video to showcase the issue I’m seeing. The issue with 1 bulb on the jig closely relates to what I’m seeing with what I’m seeing on the ones I installed previously controlling 2 and 3 of the same bulbs. Although in the wall most of the time now I can’t use the smart switch at all when the dumb switch is in the “bad” position.
Ignore the other dumb switch. It’s on there to make sure the 3 way circuit was working correctly before putting the smart switch in. This same jig works fine with the dimmer switch unless I switch the dumb switch quickly and then sometimes the smart switch doesn’t seem to recognize the change and stays in the previous state until I cycle the smart swtich and then it’ll turn on/off quickly to “catchup”.
Awesome, I will PM you shortly when I’m back home. Thank you so much!
Can you let me know what materials you were using in the jig (ie: LED make/model and schematic setup)? I have a similar one that I test on and it’s wired with line/load in different boxes, but 8n a traditional 3-Way setup (ie: Smart switch = Black to Line, White to neutral, Red to Traveller, Black to Load / Dumb switch = Neutrals capped, Travellers to Traveller terminals, Load to Common).
Edit: So I messed around and installed light fixture to the rig and am able to replicate! I was using a standard A19 prior to no avail, but for some reason the fixture is definitely causing the same results as you. Videos incoming!
Shared Album Link:
@harjms @exo @Blivit is this pretty much what you’re seeing?
@Eric_Inovelli yes that is what I am seeing here. Black series on/off switch.
@Eric_Inovelli - Close or similar for me. I couldn’t see if your smart switch ever turns the led off or not. E.g. Smart switch on, dumb switch off (my blue led remains on and bright), but lights to turn off. Vice versa, if smart switch is off, dumb switch on (toggled), it never turns on smart switch or exterior lights. Led remains dim level.
Ok perfect, this is definitely a good sign that I can replicate it.
Now I’ll be able to work faster with the manufacturer to figure out the issue.
@Courtney_Inovelli - let’s send out a package tomorrow with the above materials!
@harjms - I’m 99% sure this is what’s happening to your garage setup.
@exo - thanks for rigging this up and using a fixture - I know others had issues with their A19 or BR30’s, but I could never replicate it until now!
Here’s a crude drawing. In the video there’s an extra dumb switch but that one isn’t being used. It’s just left over from making sure the circuit works fine with dumb switches.
The dumb switch is a leviton double pole. The light bulb is EZ lighting EZ-A615-BA-2700K . Here’s a link https://www.warehouse-lighting.com/products/led-5-6-15w-baffle-trim-downlight
It seems like the smart switch isn’t sensing the dumb switch correctly when the dumb switch is set to the travel leg.
@Eric_Inovelli - Perfect.
Yup this video is what I’m getting on the jig as well. Now you can swap a dimmer switch in place and it’ll work except for fast dumb switch toggles.
