Plans to join Home Assistant's built-in OTA firmware update?
What’s the correct order :grinning: ?
1 then 0, but I saw an improvement to zwavejs that’s coming out that should fix this :crossed_fingers:.
Thank you so much!!! I sent this and fully anticipated a snarky RTFM reply that would mean I’d have to spend another hour or so hunting for docs or “that one post” somewhere :grinning: Updating target 1 followed by target 0 has worked perfectly on 2 of 3 LZW31-SN I needed to update. I’m assuming the third will be just as smooth.
There’s no FM for this at this point. I figured it out by trial and error.
OTA never shows up for my black series. Is this supposed to work today?
I don’t see the LZW31 in the list of currently supported devices, so it won’t work. I only see red and black on/off switches and LZW36.
LZW31 has been removed for 4 months:
The commit description is " Temporarily remove Inovelli LZW31-SN until multi-target firmware updates are fixed"
Will whatever this is referring to be fixed by Inovelli soon? If it already has, can this be driven to the zwave-js folks? The manual method of updating looks very heavy vs. using a simple web UI. Thanks.
This is all on the ZJS side. Outside of Inovelli control 100%.
