To make it easier to troubleshoot your issue, please provide the following when posting:
Model # of your smart switch: Red Series Dimmer (LZW31-SN), Red Series On/Off (LZW30-SN), Black Series Dimmer (LZW31), Black Series On/Off (LZW30), Fan/Light (LZW36)
Neutral or Non-Neutral Setup: Please provide whether or not you have a neutral wire – if unsure, it’s ok.
Single Pole, 3-Way, 4-Way, etc: How is your switch wired?
- Single Pole = One Switch to one Load
- 3-Way = Two Switches to one Load
- 4-Way = Three Switches to one Load
- 5-Way = Four Switches to one Load
Multi-Switch Setup (ie: 3-Way, 4-Way, etc): Are you using a dumb/existing light switch or are you using an auxiliary switch (GE, HomeSeer) with your Inovelli switch?
Pictures: It makes things so much easier if you could provide pictures when posting. The more angles of both the smart and dumb switch, the better. A good example is one like this:
The above shows multiple angles of the dumb switch so we can see where the wires are coming from in the gangbox and also see where they are going on the switch.
Common Troubleshooting Links:
Please read through the troubleshooting links below to solve for the most common problems.
- Neutral & Dumb Switch Troubleshooting
- Neutral & Aux Switch Troubleshooting
- Non-Neutral & Aux Switch Troubleshooting
FAQ’s
My Dimmer switch is wired correctly, but it’s not working properly in a 3-Way (or multi-switch setup). Help!
- The dimmer switch (applies to both the Red & Black Series Dimmers) needs to be programmed to work properly in a 3-Way setup. Please see the YouTube videos below for instructions:
