Plug-in zwave outlet recommendations
I’ve been happy with the Leviton DZPA1 - simple zwave outlets. I have two, and I like there is a physical switch to also control. Think of it like the physical part of your light switch - crucial if the zwave part goes out. It also has an Identify feature, blinking the light so you know which one is being controlled.
I also use it as a zwave repeater (don’t buy a repeater-only device, get some add’l value here!)
I can’t see a marking difference, but that physical control button only works on my “newer” one from a 2019 order. One I got from ~2017 doesn’t work that way.
If someone has bought this and likes another brand, I’d appreciate hearing it.
