Placeholder for the Aeotec Water Leak Sensor
Product Overview
Product Videos
Official Videos
Community Videos
Compatible Hub/Gateways
Below is a list of compatible hubs and gateways. Feel free to click on the links to be taken to the product page and/or select the dropdown to see a visual of the product (they are links too). If you do not see your hub or gateway on the list, please reach out to us prior to purchasing.
ConBee II - ZigBee USB Dongle
NOTE: If using Home Assistant, this stick can run on ZHA or Zigbee2mqttGoControl - ZigBee USB Dongle (HUSBZB-1)
NOTE: If using Home Assistant, this stick can only run ZHA (not zigbee2mqtt) unless you update the firmware. GitHub linkLinear - ZigBee USB Dongle (HUSBZB-1)
NOTE: If using Home Assistant, this stick can only run ZHA (not zigbee2mqtt) unless you update the firmware. GitHub linkNortek - ZigBee USB Dongle (HUSBZB-1)
NOTE: If using Home Assistant, this stick can only run ZHA (not zigbee2mqtt) unless you update the firmware. GitHub linkSonoff - ZigBee USB Dongle (CC2652P)
NOTE: If using Home Assistant, this stick can run on ZHA or Zigbee2mqttDISCLAIMER: As an Amazon Associate Inovelli, LLC earns from qualifying purchases.
