Project Europa | 240V Smart Switch(es) For Europe (EU) - Zigbee, Thread/Matter
I am coming here over from LTT, after watching Linus test out your new dimmers.
While I do not live in Europe (not only we are not part of the EU, we are also on a different continent), our standards are mostly based upon EU standards, so this is the best place for me to chime in.
Personally, I would recommend a combination of all three kinds, with removable plates (but the actual modules, and yes, it would be better for them to be modular, similar to offerings from Legrand, Schneider Electric, Gewiss, BTcino, Vimar, and others), so as to more easily and feasibly cater for more tastes at once.
Also, in regards to the last kind, going modular will immensely help go towards abiding by more regulations, as Europe has 3 different standards for mounting, with one having 2 mounting options, and will help in expanding to the rest of the world more easily as well.
The standards are as follows:
UK: The boxes and plates are square, with the plates at roughly 86mmx86mm for single gang, roughly 146mmx786mm for double gang (ignoring switch gangs, as the boxes are the same), and for architrave it is roughly 86mmx32mm for single gang and roughly 146mmx32mm for double gang.
There are two parallel screw holes. which I believe can either be on the right and left or on the top and bottom with the length between them being 60.3mm with single gang sockets and from single to triple gang switches (yes, this is confusing to me as well, since we do not use these standards in my country), as well as single gang architrave switches, and 120.6mm for double gang socket and 4/6 gang switches, as well as double gang architrave switches.
China had adopted the UK standards for the dimensions of their boxes and plates, however they expanded upon them to allow for up to 5 socket gangs, I believe (I have no idea regarding switch gangs).
Switzerland: Honestly, I’m still having trouble understanding where to look for information about the Swiss standards for the boxes and plates/frames, so I’ll post this link to Legrand’s Swiss mounting plate with an Arteor frame adapter on their Swiss Catalogue website, as it contains links to PDFs that may be helpful.
Switzerland may be slowly adapting the EU and Italian box standards, however I have no conclusive evidence either way.
Italy: Originally a BTcino innovation based upon Pass&Seymour’s modular switch system, the Italian socket boxes are based upon US socket/outlet boxes, but expanded upon, and completely modularized (also Japan did this, but in a different way).
Firstly, instead of three parallel screwholes on either side, there is only one parallel screw hole on either side, with the distance between them being roughly the same as the two main/closest screwholes in US boxes, with 3-module boxes.
Second, there are 3-, 4-, and 7-module boxes, with 2-, 3-, 4-, 6- and 7- module frames and 1-, 2-, 3-, 4-, 6- and 7- module plates, depending upon the manufacturer, series and requirements (unlike Japan, there is no standard regarding the modules themselves, so modules are not necessarily interchangeable, even between different lineups from the same manufacturer), and some manufacturers also providing 2- and 3- row boxes, frames and plates in accordance to the above as to modules.
The grouping is as follows, 1-, 2-, and 3-module plates with either 2- or 3-module frames (depending upon the lineup, some have 2-module only with 2-module) and 3-module boxes, 4-module with 4-module, and 6- and 7-module plates with either 6- or 7-module frames (again, depending upon the lineup) and 7-module boxes.
There are no limits on frame and plate dimensions, except for the screw positions.
EU boxes, frames and plates exist, but are extremely rare.
Most of Europe: Round boxes, ~55mm/~60mm/~67mm (same internal dimensions, just different parts measured in different countries) for single gang and larger ~70mm (the measurement in my country, I am not sure about others, but again, same internal dimensions) round boxes for junction boxes, with some countries also using UK boxes for some purposes (I have no comprehensive list, but at least France is amongst them), that can either have or not have (the latter is mostly in ancient houses) parallel screw holes that can either be at the sides or top and bottom (or if the electrician has no idea about their purpose, as is often the case in my country, at any direction) with roughly 60mm between them.
There are no standards as to the dimensions of the frames and plates, except for the screw positions.
And there are two methods of installation, the old way, which is required in houses with boxes that lack the screw holes, where claws are held on the back of the frame with screws, and tightened against the sides of the boxes, and the current way, where the screws screw into the box (often coming with the box), you slightly loosen them, guide the frames on them, twist them to the side (the frames have rounded socket groove tracks, with a larger cavity to allow the screw head to go through) and tighten the screws.
Additionally, the newest part of the EU standard adopts (alongside, not replacing the existing standards) elements from the UK (architrave boxes and frames as 1-module) and Italian standards (3 module boxes and frames, and modularization in general, turning the old round boxes into 2-module boxes), and adapting them to the existing standards (namely, the frame installation process), with rounded rectangle boxes of 5-, 8- and 11-modules (2-, 3- and 4-gang, respectively, with 5-gang also existing, but less common, and only using 5x 2-module frames), and accompanying frames (while retaining compatibility with existing 2-module frames) and plates (1-, 2-, 3-, 4-, 5-, 6-, 8-, 10-/11-modules and 2-, 3-, 4- and 5-gangs), and 2- and 3-rows of these also exist (not for 5-gang).
The screwholes in architrave and 3-module boxes remain the same as in their UK and Italian counterparts), but you have the same ease of installation benefits as with the 2-module boxes, on 5+ module boxes the screwholes are only at the top and bottom, so as to retain compatibility with 2-module frames that fit into each others like puzzle pieces, so the 5±module frames have just as many screwhole grooves, but instead of twisting them, you move the frame to the side, all else the same.
The grouping is as follows, 1-module architrave plate and frame with architrave box, 1- and 2-module plates with 2-module frame and 2-module box, 1-, 2-, and 3-module plates with 3-module frame and 3-module box, 4-module plate with 4-module frame (mainly Italian frames compatible with both systems) and 4- and 5-module and 2-gang plates with 5-module frames (the latter plate also with 2x 2-module frames) and 5-module boxes, 6- and 8- module and 3-gang plates with 8-module frames (the latter also with 3x 2-module frames) and 8-module boxes, 10-module and 4-gang plates with 11-module frames (the latter also with 4x 2-module frames) and 11-module boxes, and 5-gang plates with 5x 2-module frames and 5-gang boxes.
The multi-gang plates can also be used with the 2-module frames in separate 2-module boxes that are installed next to each other.
Again, like in Italy, there are no standards as to the modules themselves, so same situation in regards to compatibility, and oddly enough, actual market penetration of modularized systems as opposed to ganged systems, is very slow outside of France.
South Africa, though it uses the same boxes as in the US, have also started adopting modular systems, and also the 8-module boxes and frames.
My country uses both the EU (not yet including the 5+module or architrave boxes, though I plan on changing that, and despite also having everything for the newer screw-based installation method, most electricians are unaware, and install with claws, despite the preferred standards having changed over 50 years ago) and Italian standards (but next to no one is aware that the 7-module boxes are not just for 6-modules, so there are next to no 7-module frames here).
India, I believe, either use UK boxes, with or without the Chinese extensions, EU boxes, or both, though I am not yet sure.
Thailand and the Philippines use US boxes (they are 220~240V, though, despite the sockets officially accepting NEMA 5-15P plugs, with usage of NEMA 1-15P and 5-15P plugs for these voltages being officially standardized in the Philippines).
Brazil, and most of South America, use US boxes (Chile may be using Italian boxes, I am not sure, and the voltages vary, to the point that both ~120V and ~240V can be officially used in the same house, like in Brazil).
I believe that Malaysia uses UK boxes.
I believe Indonesia and South Korea, as well as northern African countries, use EU boxes.
Other countries, I still have yet to learn about.
As for modularization, while I do not know on a per-country basis, I believe that most of the world has adopted to one degree or another (Japan literally standardized almost everything there is to standardize, down to screw torques and module compatibility, which I believe is also the basis to Panasonic’s offerings in Thailand and the Philippines).
Sorry about the extremely long post, I have quite the enthusiasm on the subject, which has helped me get closer to joining courses in electricity in order to be a registered electrician here (I am still waiting for an answer as to when the next semester will be where I wish to learn).
Also, I am all for KNX support (best direction in my opinion for securirt- and privacy-focused and most efficient smart home automation solution, especially as it is properly standardized with open standards anyone, not just manufacturers, could develop for), though I care little about smart home automation (but am still excited about new developments in the field), as I prefer things to be as manual as possible, and KNX could, in conjunction with magnetic breakers disguised as switches, offer a solution to my OCD with multi-way switches (I like them all to be in the same position, either up when on or down when off).
That is not just common in the US, Live-only switches are very common in general, and unfortunately, many electricians around the world cut corners by running the wires directly to the appliance, and from there run two Live wires to the switch, one to and one from.
Personally, I would prefer standards mandating dual-pole switches for all new installations, and wires first going to the socket box with the switch, before going to the appliance (thankfully, with sleeved cable bundles (L+N+E) being mandated in many parts of the world, this specific cornercutting is slowly going away).
Ah, I forgot.
I believe Australia uses the same boxes as the UK, though I am not sure if single gang and architrave boxes are used there.
Yes, please! Also from Norway here. Been desperately wanting Inovelli tech here for a long time. And @skoging is right, we tend to be forgotten quite a lot (sometimes intentionally) because of the literal headache it is to navigate Norwegian tax laws.
Hello, one thing I have read hear is the whole sensor “thing”, with not enough space for the sensor or in case of mmWv no experience, or ather things.
So my thought was, why not make a Sensor unit, that does not have tha capabilities to switch a load but hase a temp, humidity, … Sensor and maybe a button or two on the front.
This way one can outfit there house with switches for now and leaf a empty plate where the, whant sensors later. And when you have a better footing in the EU market, you can release this sensor unit which then can be installed.
Why leave an empty plate, when you can instead have the switch as a module?
That way you could install a sensor-less switch, and later, without removing the frame, just replace the sensor-less switch with a switch that contains the sensors?
This also has the added benefit, that you can easily have replaceable faceplates for the module itself, for different colors, styles, etc., as well as different widths being possible withe the same module, for those who like them wider.
For example, you could have one that is 1-module wide (1/2 EU gang), as is common in Italy, and will also fit in an architrave frame, and put it in a 2-module/1-EU gang frame, with 1 1-module plate, or with 2 1/2-module blanks, or conversely, with 1/2-module supports, have the module faceplate be 2-modules wide, and with 1-module supports or a special plate for the frame that has the supports built-in, have it be 3-modules wide, with additional options for those who prefer them be taller.
Think we are long overdue an update on this @Eric_Inovelli if possible?
Hello! I live in The Netherlands. Very interested in a ZigBee + mmWave switch. That would be pretty amazing.
I guess finding a fulfillment company has been impossible
It would just be nice to know. An update saying nothing is better than no update.
It’s been nearly 2 months since the fulfilment company emails looked promising.
Hello from Czech Republic here! Very excited to be part of the community and to be able to look at the process in real time :slight_smile: Since I am moving in 3-4 months and am determined to make my flat “smart-er”, I´m also up for testing. If you would like to have feedback from a newbie and home automation novice (read- dumbass). Looking forward to it and good luck!
@Eric_Inovelli so sorry for being late on this one. I’m still watching, looking and hoping.
Here’s a thought. if you do 220/240v - does that not also give you an opportunity in North America where I’ve seen people asking for smart switches that do 220V for dryers, etc?
I am not part of the staff, however unfortunately that is not the same thing.
The NEMA 220V and JIS 200V (yes, 200V) are dual-phase Neutral-less connections, unlike our single phase+Neutral 230V.
And an update, regarding the screws required for installation, since I finally have the proper dimensions (though I still need to finish reading up in the matter, and I still lack information about the Swiss standard):
European: M2.5 (~5mm head)
Italian: M3 (~6mm head)
British/Australian/Chinese: M3.5 (~6.5mm head)
NEMA: M3.5 (~6.7 head)
JIS: M3.5 (6.5mm head)
A note about socket boxes in Australia, while I have not yet managed to verify this, it may be possible that Australia (and possibly also New Zealand) only use British 2-Gang socket boxes, even when only one socket monoblock is installed (and thus their 1-socket monoblocks are as wide as their 2-socket monoblocks).
This would be a wonderful addition to our house :star_struck:
Also representing the Norwegian market, and hoping you won’t forget about us :sweat_smile:
Hi, I am joining this thread!
I know I’m quite late, but I hope my feedback still helps.
Where I live (Hungary), I’ve seen the switches next to each other in home setups, which makes sense considering we usually divide the switches vertically.
(Note: I don’t have 2 switches next to each other in my personal home, only outlets, so this image has to do.)
I still love the vertical LED designs better, similarly to the right ones in Eric’s post.
Now, while I don’t have a solution for the 3-gang switches, I believe the following (terrible) mock-up would work quite well for the 2-gang ones:
Mockup of a 2-gang switch
They look great even when put next together, not just under, since in the EU there’s always a gap between the switches.:
And them being under each other is definitely great too, as the lines form a single line then. (True for horizontal LEDs in my case, but I think, horizontal LED ones being under each other wouldn’t look as great as vertical ones next to each other… Which is weird, considering it’s just the same thing, rotated 90 degrees.)
Most commonly I feel like I’ve seen 2-gang and single ones so far, I don’t necessarily think 3 gang ones are even needed.
If the number of switches needed in the same place is…
  • …odd (1, 3): I always found them as 1-gang ones put next to each other.
  • …even (2,4): I’ve seen either all 1-gangs or all 2-gangs. Pretty much an even mix of the 2 options.
3 gang ones are simply not a thing here as far as my experience goes. They are also too small for those, who have large hands. (Note: If, for example in my old schools, the number of switches was an odd number of 5 or higher, then it was all 2-gang ones except the last one which was a 1-gang one or still all 1-gang ones. For example 7 switches: was done by 2 rows of 4 1-gang switches with one being an outlet instead of a switch. Highly unlikely scenario in most homes IMO.)
Considering the pre-orders have yet to start I would love to have this revisited.
Now, continuing on this, mentality, I can see many people request many different things, if the inner (controlling) part of the switch could be rotated it would be cool, even if it’s most likely not feasible (I’m just throwing some ideas out there.).
  • Basically, the body of the controlling part is a square, with only the LED part needing 2-4 connectors, so they can work in either horizontal or vertical setups (or 4 connectors for the double ones, which works only in the above mentioned scenario).
  • Then, the cover should be applicable in either orientations (Snap on to the controller, as it’s a rectangle).
The covers not being permanently attached to the switches would also solve a lot of other issues, like colour requests, horizontal and vertical alignment issues, etc. as they could easily be sold separately over time, and you could even make an option on which covers you’d like to have shipped with the switch later on. (Or just provide 3D models so people can print them in whatever colour they want. Which would align with the “you own your home” mentality.)
(Edits: grammar)
Hey guys,
Just wanted to give an update as I know I’ve been a bit dark on this thread.
I’ve had to figure out a Plan B here because even though Shopify said they were able to help with their, “Managed Markets” program (as a refresher, this was a program that would handle all the duties and tax implications by being the importer on record), they ended up backtracking on it and said they are not ready for the EU yet. A real bummer as I had to restructure our entire site which took me a few days to adhere to their policy. They said sometime in 2025 they should be ready. I’ve confirmed this with the distributor who was on board with us.
So, I’ve went ahead and secured a, “digital citizenship” to Estonia so that we can set up a business in the EU, which is one of their requirements for collecting/remitting taxes. This still leaves me trying to figure out the UK, but I guess we’ll cross that bridge when the time comes.
I have to go pick up my “digital citizenship” card in Washington DC the first week of January. From there, I plan on registering and trying to figure out the rest of the logistics.
As an aside, if there is anyone here who is an expert in this field (e.g., a US company trying to sell in the EU and navigating the tax implications and import issues), I am all ears.
This feels like you keep getting burned by companies initially promising you something and then pulling the rug out from under you. Really sucks, and sucks even more when people then turn around and blame you for having to push back a deadline that most companies would not have shared in the first place. Just wanted to let you know we recognize how hard you work and what you’re up against and are rooting for you!
Hi Eric,
happy new year there. Just got to know about Inovelli. I’m in Europe and looking forward to the new Matter products.
One thing I would like to ask about the Matter Dimmer Switch, I see there’s a mode to control Smart Bulbs providing 100% power at all times and control via software, I wonder if the dimming function of the switch can also work with the smart bulbs.
Thanks for any info on this.
