Red On/Off Auto Off Timer animation
I love the VZW31-SN Red dimmer. When the Auto Off Timer parameter is set and the switch is turned on, then the LED shows a countdown animation.
I bought VZW30-SN for my exhaust fans expecting the same behavior, but the LED doesn’t do a countdown animation when Auto Off Timer is enabled and the switch is turned on. Bummer. :frowning:
Can you please update the firmware for VZW30-SN to behave the same way as VZW31-SN with Auto Off Timer? It has an Auto Off Timer parameter and the VZW30-SN LED seems capable of displaying a countdown animation (Advanced Timer Mode parameter does this with 2x-4x taps).
This Auto Off Timer animation + the humidity sensor would be perfect for shower fans.
This is actually something I’ve been looking at for my incoming on/off blue series switch. Don’t have it in hand yet, but when I do, I’m hoping to setup a controller in my Home Assistant instance to allow holding down the paddle to change the remaining time on the timer, and then leave the animation to show what’s left. If this is built into the firmware, all I need to do is modify the auto off parameter and leave the switch to handle the rest.
