RGBW bulb stuck on blue
So I have a bulb I’ve been using for around a month that suddenly just turned on and was blue. The bulb is only ever turned on/set through associations with a red dimmer, so I was not sure why it was blue.
When I went to fix it, I can change the color but none of them are correct. Yellow is more like green, and orange is blue. I’m guessing that the red LED is dead or something.
When I set the color temperature to warm white, it is just a faint blue.
I’ve tried excluding and factory resetting, no luck.
Any thoughts?
RMA if factory reset didn’t fix it.
Were you able to solve the problem? I have the same issue.
Hey @vaughnjohnson,
Try a hard reset using the instructions at the link below. If the blue tint is still there after doing the hard reset, reach out to us at [email protected]
How To: Include / Pair, Exclude / Remove & Factory Reset Ilumin Bulbs
