Run Action Twice for Lights to Change Color
Hello,
I’ve noticed an issue when changing color to the lightstrips since I first set them up. Whenever I change the color on them, or send a command to change the color, I have to send or perform the action twice for the color to update properly. Has anyone encountered this issue?
For example, I’ll perform a button press to activate a scene, and the lightstrip color won’t update, but the other lights will. If I hit the button press again, the lightstrip will update.
Using zwavejs2mqtt + HA.
