Hey all, just wanted to post up that I FINALLY got a working solution to set default levels based on adaptive lighting component called “default levels”. I’ve tested it for a few days and it works really well. It also uses an “only if changed” rbe node to keep the z-wave traffic to a minimum. Figured I would share and solicit for improvement.
Largest bummer is that it has to use a polling node since the on/off is the only “state” that changes on the switch. I haven’t been able to figure out how to get a trigger to fire when an attribute of an entity changes:
[{“id”:“a980282e.2b4478”,“type”:“tab”,“label”:“Default Lighting Levels”,“disabled”:false,“info”:“”},{“id”:“8fb229d5.b2d418”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Dining Room Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.dining_room_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1510,“y”:100,“wires”:[]},{“id”:“97b45e5a.f00ad”,“type”:“change”,“z”:“a980282e.2b4478”,“name”:“for Dimmers Default Local”,“rules”:[{“t”:“set”,“p”:“parameter”,“pt”:“msg”,“to”:“9”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:830,“y”:480,“wires”:[[“397599e7.35b066”]]},{“id”:“1d807676.744dea”,“type”:“change”,“z”:“a980282e.2b4478”,“name”:“for Dimmers Default Z-wave”,“rules”:[{“t”:“set”,“p”:“parameter”,“pt”:“msg”,“to”:“10”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:840,“y”:560,“wires”:[[“397599e7.35b066”]]},{“id”:“f95b0ac4.2768b8”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Master Hallway Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.master_hall_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1520,“y”:880,“wires”:[]},{“id”:“e49e7da5.3490a”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Master Bathroom Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.master_bathroom_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1530,“y”:160,“wires”:[]},{“id”:“76b76ed7.6d776”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Master Bedroom Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.master_bedroom_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1520,“y”:220,“wires”:[]},{“id”:“625969e1.7e0dc8”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Living Room Hallway Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.living_room_hallway_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1540,“y”:280,“wires”:[]},{“id”:“6f9012f7.8caf3c”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Dining Room Track Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.dining_room_track_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1530,“y”:340,“wires”:[]},{“id”:“e46a69d3.61be08”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Dining Room Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.dining_room_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1510,“y”:400,“wires”:[]},{“id”:“9b5a0021.a5238”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Living Room Entry Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.living_room_entry_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1530,“y”:460,“wires”:[]},{“id”:“b9586f8d.171b1”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Living Room Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.living_room_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1510,“y”:520,“wires”:[]},{“id”:“a8433b92.2825c8”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Upstairs Main Hall Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.upstairs_main_hall_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1530,“y”:580,“wires”:[]},{“id”:“5d2e345b.34c9ec”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Upstairs Hallway Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.upstairs_hallway_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1520,“y”:640,“wires”:[]},{“id”:“19b921da.8ef03e”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Guest Bathroom Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.guest_bathroom_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1520,“y”:700,“wires”:[]},{“id”:“370a48e8.03f408”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Guest Bathroom Shower Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.guest_bathroom_shower_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1550,“y”:760,“wires”:[]},{“id”:“53e0658.15b269c”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Guest Bathroom Sconces Dimmer”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.guest_bathroom_sconces_dimmer_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1550,“y”:820,“wires”:[]},{“id”:“397599e7.35b066”,“type”:“split”,“z”:“a980282e.2b4478”,“name”:“”,“splt”:“\n”,“spltType”:“str”,“arraySplt”:1,“arraySpltType”:“len”,“stream”:false,“addname”:“”,“x”:1090,“y”:480,“wires”:[[“8fb229d5.b2d418”,“e49e7da5.3490a”,“76b76ed7.6d776”,“625969e1.7e0dc8”,“6f9012f7.8caf3c”,“e46a69d3.61be08”,“9b5a0021.a5238”,“b9586f8d.171b1”,“a8433b92.2825c8”,“5d2e345b.34c9ec”,“19b921da.8ef03e”,“370a48e8.03f408”,“53e0658.15b269c”,“f95b0ac4.2768b8”]]},{“id”:“df4b7f5b.f9405”,“type”:“comment”,“z”:“a980282e.2b4478”,“name”:“Fan/Light Light”,“info”:“”,“x”:1520,“y”:1000,“wires”:},{“id”:“22c88ced.46c2f4”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Guest Bedroom Light”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.guest_bedroom_light_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1520,“y”:1080,“wires”:[]},{“id”:“563f9ec1.7a39a”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Living Room Light”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.living_room_light_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1510,“y”:1140,“wires”:[]},{“id”:“5f10e2f8.a91e2c”,“type”:“api-call-service”,“z”:“a980282e.2b4478”,“name”:“Set Kendrick Light”,“server”:“86db4bb5.5e7458”,“version”:1,“debugenabled”:false,“service_domain”:“zwave_js”,“service”:“set_config_parameter”,“entityId”:“light.kendrick_bedroom_light_current_value”,“data”:“{"parameter":"{{parameter}}","value":"{{value}}"}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1500,“y”:1200,“wires”:[]},{“id”:“8909f930.774b88”,“type”:“split”,“z”:“a980282e.2b4478”,“name”:“”,“splt”:“\n”,“spltType”:“str”,“arraySplt”:1,“arraySpltType”:“len”,“stream”:false,“addname”:“”,“x”:1090,“y”:1080,“wires”:[[“22c88ced.46c2f4”,“563f9ec1.7a39a”,“5f10e2f8.a91e2c”]]},{“id”:“7edb80dc.1d9b7”,“type”:“change”,“z”:“a980282e.2b4478”,“name”:“for Fan/Light Light Default Local”,“rules”:[{“t”:“set”,“p”:“parameter”,“pt”:“msg”,“to”:“12”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:860,“y”:1080,“wires”:[[“8909f930.774b88”]]},{“id”:“c908a988.a55948”,“type”:“change”,“z”:“a980282e.2b4478”,“name”:“for Fan/Light Light Default Z-wave”,“rules”:[{“t”:“set”,“p”:“parameter”,“pt”:“msg”,“to”:“13”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:870,“y”:1160,“wires”:[[“8909f930.774b88”]]},{“id”:“d1cac810.6713c8”,“type”:“comment”,“z”:“a980282e.2b4478”,“name”:“Dimmers”,“info”:“”,“x”:1500,“y”:40,“wires”:},{“id”:“b71b80fa.f25e2”,“type”:“debug”,“z”:“a980282e.2b4478”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“value”,“targetType”:“msg”,“statusVal”:“”,“statusType”:“auto”,“x”:1010,“y”:120,“wires”:},{“id”:“63b6f51e.8d235c”,“type”:“change”,“z”:“a980282e.2b4478”,“name”:“”,“rules”:[{“t”:“set”,“p”:“value”,“pt”:“msg”,“to”:“data.attributes.brightness_pct”,“tot”:“msg”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:200,“y”:240,“wires”:[[“e0744d53.92f9b”]]},{“id”:“272052b1.1f615e”,“type”:“change”,“z”:“a980282e.2b4478”,“name”:“”,“rules”:[{“t”:“change”,“p”:“value”,“pt”:“msg”,“from”:“100”,“fromt”:“num”,“to”:“99”,“tot”:“num”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:530,“y”:240,“wires”:[[“b71b80fa.f25e2”,“f300bac.e67db48”]]},{“id”:“e0744d53.92f9b”,“type”:“function”,“z”:“a980282e.2b4478”,“name”:“”,“func”:“msg.value = Math.round(msg.value)\nreturn msg;”,“outputs”:1,“noerr”:0,“initialize”:“”,“finalize”:“”,“libs”:,“x”:360,“y”:240,“wires”:[[“272052b1.1f615e”]]},{“id”:“779de8c1.e73bf8”,“type”:“poll-state”,“z”:“a980282e.2b4478”,“name”:“Default Level Switch”,“server”:“86db4bb5.5e7458”,“version”:1,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:“”},{“property”:“icon”,“value”:“”}],“updateinterval”:“5”,“updateIntervalUnits”:“minutes”,“outputinitially”:true,“outputonchanged”:true,“entity_id”:“switch.adaptive_lighting_default_levels”,“state_type”:“str”,“halt_if”:“on”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“outputs”:2,“x”:130,“y”:80,“wires”:[[“63b6f51e.8d235c”,“57eb3ce9.468d64”],]},{“id”:“57eb3ce9.468d64”,“type”:“debug”,“z”:“a980282e.2b4478”,“name”:“”,“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“statusVal”:“”,“statusType”:“auto”,“x”:640,“y”:120,“wires”:},{“id”:“f300bac.e67db48”,“type”:“rbe”,“z”:“a980282e.2b4478”,“name”:“Is Changed?”,“func”:“rbe”,“gap”:“”,“start”:“”,“inout”:“out”,“septopics”:true,“property”:“value”,“x”:510,“y”:340,“wires”:[[“97b45e5a.f00ad”,“1d807676.744dea”,“7edb80dc.1d9b7”,“c908a988.a55948”]]},{“id”:“86db4bb5.5e7458”,“type”:“server”,“name”:“Home Assistant”,“addon”:true}]
