Hope this post is in the correct category. Mods please move it out isn’t.
So I have a GE/Jasco dimmer in Hubitat that I’ll be replacing with a Red Series mmWave switch that just shipped today.
With the GE switch, I’m able to use Rule Machine to effectively set the default dim level even when the physical paddle is pressed, based on time of day.
For example, my bathroom lights default to ~1% overnight so I don’t get blasted when I stumble in and hit the wall switch. This works reliably today (see screenshots of the rule below).
On the Red Series, is it possible to set the “Default Level (Local)” or equivalent parameter via Rule Machine using a custom command?
I understand the Red Series supports Default Level (Local/Remote) via Z-Wave configuration parameters, but when I look at custom commands on another Red Series switch, I don’t see any command that would allow changing that default level dynamically from a rule.
Before I install the mmWave switch, I just want to confirm:
Is there any supported way to modify the default ON level from Rule Machine?
Or is the only option to let the paddle turn the light on first, then override the level after a delay (which risks a brief ramp to the local default)?
Thanks — just trying to confirm expectations before swapping hardware.
