Setting single Color in Scene
I am trying to figure out to set up something using the Red Series Light Strip that will allow it to turn on to one color that is not white. Also some of the effects builtin I would like to know how you can change the color on it. I am using Home Assistant to control it.
Since you’re using HA, I’d recommend adding the Zwave JS script from here for pixel effects.
I would also recommend setting up this Blueprint to handle a color change fix as well.
Once you’ve got both of those, if you’re looking to change the default color when it turns on, you’re looking for parameter 9 I believe.
If you just want to change the color once it’s on, you should be able to click the icon from your dashboard and you’ll get something like this -
