I’ve been looking through the docs and can’t seem to find my specific wiring diagram. So I’m looking for some assistance. I’m hooking up my blue series fan switch to my bedroom ceiling fan with light. It’s a single pole gang box with neutral but it’s got 2 load lines, one for the fan and the other for the light. I’m not using a canopy module. The way I’m wanting it to work is that I’ll have smart control of the fan both through the switch configuration and Home Assistant. And I need constant power to the lights because they are Philips Hue smart lights controlled by a separate Hue Dimmer Switch. I would greatly appreciate some help with wiring this out. I’m probably overthinking it but my idea is for the light (load) and line to the line terminal and the fan (load) to the load terminal. Would this be correct?
Yep. I am presuming that you have a 3-wire going to the light. You will need to send the neutral as well. Bundle the three neutrals in the switch box and then pigtail to the neutral terminal on the switch.
