Smart / Aux / Dumb in one wiring
Can you wire a smart, dumb and aux in one wiring?
Reason I am asking is because I have a set of lights with 4 switches. I replaced the main with a smart. Things worked as expected (smart could control, others could control, but not together)
So I replaced one dumb with an aux and went to test it. Does not work as expected. Is this because you can’t have aux and dumb in the same wiring?
Was just trying to go switch by switch and test so I knew each installation was correct before I went to another?
And in this instance, aux’s are wired line and load together, traveler and neutral to aux?
Yes.
That is a good approach, but disconnect all of the dumb switches and then add one Aux at a time.
