Smart bulb not adding to Zooz USB stick on Home Assistant
I have a Zooz ZST10 S2 Z-Wave Plus USB Stick connected to a
Raspberry Pi 4B that is running the home control software
Home Assistant 0.103.5
The USB stick is configured and shows the configuration as ready.
I want to pair it with a smart bulb
ilumin RGBW smart bulb LZW42
I followed the bulb instructions for pairing by powering it up
which causes it to blink twice then I click ADD NODE on the
Z-Wave Network Management page… Nothing I have varied the sequence
many ways. I have also tried the ADD NODE SECURE button.
Here is the OZW log after a restart server an an attempt to add node
2020-01-10 13:29:19.052 Always, OpenZwave Version 1.4.3452 Starting Up
2020-01-10 13:29:27.026 Info, Setting Up Provided Network Key for Secure Communications
2020-01-10 13:29:27.027 Info, mgr, Added driver for controller /dev/serial/by-id/usb-0658_0200-if00
2020-01-10 13:29:27.041 Info, Opening controller /dev/serial/by-id/usb-0658_0200-if00
2020-01-10 13:29:27.041 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200-if00 (attempt 1)
2020-01-10 13:29:27.046 Info, Serial port /dev/serial/by-id/usb-0658_0200-if00 opened (attempt 1)
2020-01-10 13:29:27.047 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-10 13:29:27.047 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-10 13:29:27.047 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-10 13:29:27.048 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-01-10 13:29:27.048 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-01-10 13:29:27.048 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-10 13:29:27.052 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x36, 0x2e, 0x30, 0x34, 0x00, 0x01, 0x94
2020-01-10 13:29:27.052 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-01-10 13:29:27.052 Info, contrlr, Static Controller library, version Z-Wave 6.04
2020-01-10 13:29:27.053 Detail, Node045, Expected reply was received
2020-01-10 13:29:27.053 Detail, Node045, Message transaction complete
2020-01-10 13:29:27.053 Detail, contrlr, Removing current message
2020-01-10 13:29:27.053 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-10 13:29:27.057 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xd0, 0x23, 0xf5, 0x71, 0x01, 0xa0
2020-01-10 13:29:27.057 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xd023f571. Our node ID = 1
2020-01-10 13:29:27.057 Detail, Node035, Expected reply was received
2020-01-10 13:29:27.057 Detail, Node035, Message transaction complete
2020-01-10 13:29:27.057 Detail, contrlr, Removing current message
2020-01-10 13:29:27.058 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-10 13:29:27.059 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-01-10 13:29:27.060 Detail,
2020-01-10 13:29:27.060 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-01-10 13:29:27.060 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-01-10 13:29:27.060 Info, contrlr, The PC controller is a primary controller.
2020-01-10 13:29:27.060 Detail, Node215, Expected reply was received
2020-01-10 13:29:27.060 Detail, Node215, Message transaction complete
2020-01-10 13:29:27.060 Detail, contrlr, Removing current message
2020-01-10 13:29:27.060 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-01-10 13:29:27.067 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x02, 0x03, 0x02, 0x7a, 0x04, 0x01, 0x00, 0x02, 0xfe, 0x87, 0x7f, 0x88, 0xcf, 0x7f, 0xc0, 0x4f, 0xfb, 0xdf, 0xfd, 0xe0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x01, 0x00, 0xe8, 0x73, 0x00, 0x80, 0x0f, 0x00, 0x00, 0x60, 0x00, 0x00, 0x30
2020-01-10 13:29:27.067 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-01-10 13:29:27.067 Info, contrlr, Serial API Version: 2.3
2020-01-10 13:29:27.068 Info, contrlr, Manufacturer ID: 0x027a
2020-01-10 13:29:27.068 Info, contrlr, Product Type: 0x0401
2020-01-10 13:29:27.068 Info, contrlr, Product ID: 0x0002
2020-01-10 13:29:27.068 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-01-10 13:29:27.068 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-01-10 13:29:27.068 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-01-10 13:29:27.068 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-01-10 13:29:27.068 Detail, Node003, Expected reply was received
2020-01-10 13:29:27.068 Detail, Node003, Message transaction complete
2020-01-10 13:29:27.068 Detail, contrlr, Removing current message
2020-01-10 13:29:27.069 Detail,
2020-01-10 13:29:27.069 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-01-10 13:29:27.071 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-01-10 13:29:27.071 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2020-01-10 13:29:27.071 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-01-10 13:29:27.071 Detail, Node172, Expected reply was received
2020-01-10 13:29:27.071 Detail, Node172, Message transaction complete
2020-01-10 13:29:27.071 Detail, contrlr, Removing current message
2020-01-10 13:29:27.072 Detail,
2020-01-10 13:29:27.072 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-01-10 13:29:27.128 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x79, 0x01, 0xa4, 0xe1, 0x10, 0x34, 0x03, 0xda, 0x5b, 0x12, 0x3b, 0x3a, 0x96, 0x71, 0x23, 0x6e, 0xd7, 0x8e, 0xd5, 0x13, 0xcd, 0x87, 0x6f, 0x5a, 0x2f, 0x1a, 0xc9, 0x52, 0xcf, 0xa9, 0x7a, 0xc8, 0x5e
2020-01-10 13:29:27.129 Detail,
2020-01-10 13:29:27.129 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-01-10 13:29:27.129 Detail, Node032, Expected reply was received
2020-01-10 13:29:27.129 Detail, Node032, Message transaction complete
2020-01-10 13:29:27.129 Detail, contrlr, Removing current message
2020-01-10 13:29:27.129 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-01-10 13:29:27.230 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x08, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc8
2020-01-10 13:29:27.230 Info, mgr, Driver with Home ID of 0xd023f571 is now ready.
2020-01-10 13:29:27.231 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-01-10 13:29:27.231 Info, contrlr, Node 001 - Known
2020-01-10 13:29:27.231 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-01-10 13:29:27.231 Detail, Node001, QueryStage_CacheLoad
2020-01-10 13:29:27.231 Info, Node001, Node Identity Codes: 027a:0401:0002
2020-01-10 13:29:27.231 Detail, Node001, QueryStage_Associations
2020-01-10 13:29:27.231 Detail, Node001, QueryStage_Neighbors
2020-01-10 13:29:27.231 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-01-10 13:29:27.231 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-01-10 13:29:27.231 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-01-10 13:29:27.231 Detail, Expected reply was received
2020-01-10 13:29:27.231 Detail, Message transaction complete
2020-01-10 13:29:27.231 Detail, contrlr, Removing current message
2020-01-10 13:29:27.231 Detail, Node001, Notification: DriverReady
2020-01-10 13:29:27.232 Detail, Node001, Notification: NodeAdded
2020-01-10 13:29:27.234 Detail, Node001, Notification: NodeProtocolInfo
2020-01-10 13:29:27.235 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-01-10 13:29:27.235 Detail, Node001, Notification: ValueAdded
2020-01-10 13:29:27.235 Detail, Node001, Notification: NodeNaming
2020-01-10 13:29:27.236 Detail,
2020-01-10 13:29:27.236 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-01-10 13:29:27.238 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-01-10 13:29:27.239 Detail,
2020-01-10 13:29:27.239 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-01-10 13:29:27.239 Detail, Node015, Expected reply was received
2020-01-10 13:29:27.239 Detail, Node015, Message transaction complete
2020-01-10 13:29:27.239 Detail, contrlr, Removing current message
2020-01-10 13:29:27.239 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-01-10 13:29:27.240 Detail, contrlr, Removing current message
2020-01-10 13:29:27.240 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-01-10 13:29:27.250 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2020-01-10 13:29:27.252 Detail,
2020-01-10 13:29:27.252 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-10 13:29:27.252 Info, Node001, Neighbors of this node are:
2020-01-10 13:29:27.252 Info, Node001, (none reported)
2020-01-10 13:29:27.252 Detail, Expected reply was received
2020-01-10 13:29:27.252 Detail, Message transaction complete
2020-01-10 13:29:27.252 Detail, Node001, Removing current message
2020-01-10 13:29:27.252 Detail, Node001, Query Stage Complete (Neighbors)
2020-01-10 13:29:27.252 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-01-10 13:29:27.252 Detail, Node001, QueryStage_Session
2020-01-10 13:29:27.252 Detail, Node001, QueryStage_Dynamic
2020-01-10 13:29:27.252 Detail, Node001, QueryStage_Configuration
2020-01-10 13:29:27.252 Detail, Node001, QueryStage_Complete
2020-01-10 13:29:27.252 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-01-10 13:29:27.252 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-01-10 13:29:27.252 Info, Node query processing complete.
2020-01-10 13:29:27.252 Detail, Node001, Notification: NodeQueriesComplete
2020-01-10 13:29:27.253 Detail, contrlr, Notification: AllNodesQueried
I have what sounds like an identical setup, running Home Assistant and attempting to interface with this bulb, LZW42 on a Zooz ZST10 (though I’m on a NUC rather than a Pi). What’s odd, is that when I configured my first bulb, it actually worked perfectly. It was on adding the second bulb that the devices began being unrecognized types, and seemed to essentially fail to respond entirely.
I followed approximately the same procedure you followed to begin with.
I would love to get these bulbs working! It was so encouraging that things worked fine out of the box and now it’s all bricked. At least I left one in a lovely shade of lavender before it went out.
I finally got Home Assistant to recognize the node. Instead of trying the ADD NODE in Z-Wave control panel. I selected SERVICES at the top of the developer control panel and selected ADD NODE from that menu and followed the instructions. Now the bulb is recognized and functions YEAH!!!
