Hi all,
My inovelli white dimmer switch is not working with my smart light. The smart light flickers when off. Does anybody have any advice? Do you think this is fixable, or should I pursue another path?
I have a white dimmer switch set to smart bulb mode and a Lifx overhead smart fixture. Because the switch box lacks a neutral wire, I have a bypass in fixture:
I initially installed without the bypass and unsurprisingly that was a mess. If the light fixture didn’t have power the switch went dead and the up light and downlight flickered badly. Neither were server-connected.
With the bypass the behavior is better, but not fully functional. When I turn the light off through the Lifx app the switch’s side light cycles “off - cyan - green - blue” and remains blue. The fixture’s uplight then flashes in an irregular sequence of colors. It remains server connected and responsive.
The same model light (I have two) works fine with a normal switch left in the on position.
Do you think this is a solvable problem? I’m inclined to go without the Inovelli switch, cover the switch plate and find a wireless remote button.
Thanks for your guidance!
